1998 z28 squeek in sterring wheel when turning
I don't know if Fbodys would exhibit the same condition, but on newer cars (Equinox w/hydraulic p/s, and Traverse) the rubbing/squeaking noise while turning heard only IN the car is actually a defect in the steering rack and transmits the noise to the passenger compartment.
Mark and disconnect the steering shaft to see if the noise goes away. If not, its probably a rack or p/s line issue. If it goes away disconnected, grease the horn contacts.
