Cooling Fans Problem
Fan Relay 1 in: Neither fan
Relay 1 and 3: Passenger side fan on
Relay 1 and 2: Driver side fan on
Relay 2: Driver side fan on
Relay 2 and 3: Driver side fan on
Relay 3: Neither fan
Relay 1, 2, and 3: Both fans on
Does the same no matter what other relays are or aren't plugged in. All the fuses are good.
Dunno if this may be related, but it's also a problem. A/C doesn't work and if I turn the A/C on inside the car, fans don't kick on. This is where it gets a little convoluted. A/C lines read about 45 psi. It looks like the clutch isn't engaging on the compressor when I turn the A/C on. But one thing I did notice was that when I turned the car to KOEO, when I put the relay in place, there was a clunk on the passenger side in addition to the relay clicking.
Questions, comments, concerns, solutions? If I can avoid a manual fan switch, that's preferable.
If you can't keep your hand on the intake....then it really is getting hot. If you can, its running at normal temps.
Only gets that hot when I idle for like 10-20 min without moving.
