tr55
If you have a 95 Z (my assumption from your screen name), then you have an LT1. The first time I changed the plugs on my LT1, it took about 200% longer than I antiscipated / expected. (I blame the guy holding the wrench!)
Anyway, get an SLP "short" spark plug socket (or make one from an extra socket), disconnect the Battery, remove the alt and the starter, and then try each plug from either the bottom or top (whatever works for you!) and take your time.
Now, after 3 or 4 sets of plugs, I can do them all from the top in about an hour, but my first time was an absolute bear!
Good luck!
Suggestion - Do one or two plugs a day; start with #1 & #3 and then walk away; get a feel for the task at hand, don't let it overwhelm you. If you can do #7 or #8 on from the top on your first attempt, you will feel quite victorious!
