windshield wiper switch
https://youtu.be/22zNxn4OuvE
ty so much, saw this along with all the others.
I actually was finally able to get everything back in, after I tried everything for hours......
so it is possible to put that follower back in once it falls out without taking off the wheel or going farther into the column. The high beams do work again, you just must make sure the high beam switch below the dash is fully pushed towards the rear of the car (you may need to lower the column to get to the screws and tighten them)
AND the cover on the left pivot pin goes in correctly tightening the plastic high beam follower. YOU MUST unscrew the tilt rod with locking pliers if you want this plastic pivot cover out.
I hope this helps other people,
thanks again
