Sponsored by: CARiD
Window Adjustment
Old Jun 9, 2012 | 10:16 PM
MIDNITE Z's Avatar
Default Window Adjustment
After the regulator and window motor are installed. How do you adjust the height of the window?
Old Jun 10, 2012 | 12:06 PM
wssix99's Avatar
Save the manuals!
If you are asking this question, you either:
- Have this problem: https://ls1tech.com/forums/general-m...-included.html
- Or something is broken
- Or you adjusted the plastic stops at the top of the door while you took out the regulator. (There are two of them.)
Typically after changing a regulator, the window glass should be right were it was before you started the job.
Old Jun 10, 2012 | 10:02 PM
MIDNITE Z's Avatar
I fix it.....I adjusted the screws on the track
