Sponsored by: CARiD
What is this?
Old Jun 10, 2012 | 01:23 PM
Sladester2's Avatar
Default What is this?
Noise coming from rear end when the back hits a bump or something. I can push it sideways a little. I was thinking maybe its something to do with the sway bar?
Old Jun 10, 2012 | 01:28 PM
mezzyshreder's Avatar
Sounds like a loose bracket of some sort. Possibly in the suspension. Put it on a lift and shake it. Have someone look for where the noise is coming from.
Old Jun 10, 2012 | 01:35 PM
Undertow74's Avatar
or your shock tower nuts are loose. regardless, something is loos and get that on a lift. or you say you can push it sideways, is your panhard rod jacked up or loose? are your rear wheels centered?
Old Jun 10, 2012 | 01:48 PM
Sladester2's Avatar
It just rocks semi-easy I will for sure get it on a lift thougj
Old Jun 10, 2012 | 04:07 PM
Sladester2's Avatar
I have had to replace my sway bar before because my last one snapped. And I just got need wheels and tires sooo could be those
Old Jun 10, 2012 | 08:18 PM
Sladester2's Avatar
It was a bolt from the sway bar. I had to replace it before guess I didn't tighten enough
