Sponsored by: CARiD
steering column
Old Jun 13, 2012 | 02:17 PM
gs462's Avatar
Originally Posted by 59 camaro
honestly every single time i use the search button on this site it NEVER works.... ive googled so much crap bout columns i need to clear my history on my macbook.... lol trust me if i could find something i wouldnt be asking here
Agreed I search all the time, sometimes it doesnt come up.
Old Jun 16, 2012 | 07:19 PM
grazi's Avatar
IMO its definately easier to replace the column than try to disect it to tighten the bolts that make the wheel loose. I had the same problem, After replacing mine, I pulled the old one apart to try to figure out waht was wrong with it...I'd say on a scale of 1-10...replacing is a 2 and disecting is a 5 or 6...There is alot of small parts and springs besides needing a steering wheel puller.
Old Jun 16, 2012 | 08:20 PM
gs462's Avatar
What did you find when you took it apart?? Is it just loose screws causing the problem?
Old Jun 16, 2012 | 08:39 PM
Wile E's 98's Avatar
Replacing the colum is easier, but chances are the new one wil do the same after a while. All gm columns get loose over time. Its best to fix the original if you can. It sucks to do because there are a lot of small parts and that makes for tedious work. If you dig down in there deep enough, you wil find four bolts that hold the knuckle for the tilt. Take them out one at a time and shoot loctite on them, then torque them back down. Remember only remove one bolt at
a time, if you take them all out its a pain in the *** to put out back together.
Old Jun 16, 2012 | 11:36 PM
59 camaro's Avatar
yeah thats what i keep hearing
ima get mine fixed tomorrow with a member from here on tech... he says he worked at GM for 38 years i trust that he'll do great!!
Old Jun 17, 2012 | 07:33 AM
grazi's Avatar
I Couldnt have explained it better
Old Jun 17, 2012 | 06:40 PM
59 camaro's Avatar
it wasent just the loose bolts, it was the housing assembly, it was all fucked up.... a member on here ls1z28 (a retired GM mechanic for 38 years) fixed my column and a bunch of other **** for my car today and man does my car feel a lot better, the column feels like a brand new car
Old Jun 17, 2012 | 06:57 PM
gs462's Avatar
I just talked to an old friend who has been rebuilding columns since the 70s he said TO HIM its easy bring it to him give him an hour and 60 bux and he'll loctite the bolts. He may do others I'll check with him when he does mine.
Old Jun 18, 2012 | 10:27 AM
gs462's Avatar
Yes my guy said it could be the same thing, he also said from how i described it he thought just the bolts would fix mine. I HOPE SO
Old Jun 18, 2012 | 05:11 PM
grazi's Avatar
My problem was where the housing pivots. the holes were rounded out and worn where the pivots were through it. The only repair was to get a new aluminum housing.
Old Jun 18, 2012 | 08:35 PM
59 camaro's Avatar
thats the same thing that was fixed on mine
Old Jun 19, 2012 | 03:03 PM
  #32
grazi's Avatar
Can you post the part number of that aluminum housing if you have it? I actually replaced by column because it was worn and the used one is worn also. I want to order that part and do it myself this time.
Old Jun 19, 2012 | 05:42 PM
  #33
gs462's Avatar
Is # 62 the piece you guys are referring too?
http://www.shbox.com/1/steering_column_exploded.jpg
Old Jun 19, 2012 | 05:51 PM
  #34
LS1Z28's Avatar
You need # 62 and #46 to repair it correctly.
Old Jun 19, 2012 | 05:57 PM
  #35
gs462's Avatar
Now if i could find the damn part numbers/ anyone?
Old Jun 19, 2012 | 06:02 PM
  #36
grazi's Avatar
Exactly, that **** was a pain in the *** to take apart, There was all springs and clips flyin off and hittin me in the head.
Old Jun 19, 2012 | 06:23 PM
  #37
gs462's Avatar
Grazi did you buy the parts? do you have the part numbers?
Old Jun 19, 2012 | 08:58 PM
  #38
59 camaro's Avatar
this guy knows what the **** hes talking about
Old Jun 20, 2012 | 10:24 AM
  #39
LS1Z28's Avatar
housing complete 26017468 includes #31-48 support steering column housing # 62 26016589
Old Jun 20, 2012 | 05:35 PM
  #40
grazi's Avatar
NO, I havent
