Sponsored by: CARiD
HELP! Another drooping drivers side mirror!
Old Jun 13, 2012 | 04:01 PM
bandit1transam01's Avatar
Angry HELP! Another drooping drivers side mirror!
Okay so on my WS6 ive noticed the drivers side mirror drooping more and more, and now today Ive noticed it seems about to fall off It droops so much that I can visually see that I have a broken bracket. The only problem I have is I have no idea how to dissasemble the mirror so I can fix this! I have tried to take off the 3 bolts from the inside and have had no luck! Can anyone help me here??
Old Jun 13, 2012 | 04:08 PM
Bump: Can anyone tell me how to take apart the drivers side mirror?
Old Jun 13, 2012 | 04:35 PM
No one on here knows how to disassemble a drivers side mirror?
Old Jun 13, 2012 | 04:41 PM
babbage1109's Avatar
I think it's on a tab type setup. Point it all the way down and look in there
Old Jun 13, 2012 | 04:42 PM
Ill give it a try, and hopefully it works. Thanks man!
Old Jun 13, 2012 | 04:53 PM
It seems like the older these cars get the more issues will happen. Still in a learning phase lol
Old Jun 13, 2012 | 06:30 PM
94'BLKBRD's Avatar
You have to remove the door panel and then remove the 3 bolts.
Old Jun 13, 2012 | 06:44 PM
Agreed lol!
Ok I did get it disassembled and hopefully liquid nails will do the trick and then Ill wrap it in tape. Thanks all for the input!
Old Jun 13, 2012 | 06:47 PM
metalmilitia606's Avatar
Just take the cover off the inside (the triangle piece) then unbolt the whole thing from the door making sure you disconnect the wiring. The bracket can be taken out. I tried to jb weld mine and it just came back apart so I got one off a wrecked car and just swapped it in.
Old Jun 13, 2012 | 06:50 PM
I also made a metal brace to kind of connect the two peices so with that and wrapping the area up with some tape to give it that extra reinforcement, it should stay. But if all else fails Ill swap it like you did.
