Sponsored by: CARiD
stalling, high idle-Please Help!
Old Jun 17, 2012 | 09:20 PM
MackTruck49's Avatar
Default stalling, high idle-Please Help!
Hey guys,
Posted this before but noone had any input...when i start my car up, it idles normal (idles high when cold then slowly goes down a few hundred rpms when warming up) Ill start driving through the gears and when i depress the clutch to grab the next gear the idle seems to climb higher (or hang at the higher rpm i left the gear at) till i put the car into the next highest gear and it (bogs down) to lower rpms due to road speed/gear selected. what the hell causes this?
It also stalls out on me when im pulling into a parking spot (turning the wheel and coasting in 1st gear with the clutch pedal depressed) especially when the a/c is on...I know its getting more strain with the a/c compressor running but its fuel injected! Please Help!
alright you son of a bitch's...haha
Old Jun 19, 2012 | 10:01 PM
CamaroAJ's Avatar
did you see if the MAF is dirty? i don't see in your mod list if it has a SD tune or not.
Old Jun 19, 2012 | 11:30 PM
whats an SD tune?
Old Jul 13, 2012 | 11:09 PM
FAD2BLK93's Avatar
Speed density
Old Jul 14, 2012 | 06:15 AM
5.7 Reasons's Avatar
I agree with CamaroAJ, pick up a can of MAF cleaner and clean that bad boy. Also, you may want to check your IAC (idle air contol) for correct operation. I had a similar issue, a couple of months ago, with my idle going high when coming to a stop or sometimes when I was out of gear. Seems like this was an IAC issue.
Then a couple of weeks ago my car felt like it would randomly pull timing, but not stall, when giving it modrate gas between 2k to 3.5k rpms. I figured that this was a dirty MAF issue, since there were no vaccum leaks. I cleaned my MAF and replaced my IAC, all is back to normal, I feel like it pulls harder after the cleaning with a nice smooth idle.
