A/C problem. 2 questions! Please take a shot at it!
Ok first when I turn on the A/C you can hear it kick on but it makes a very loud squeaky noise, like an old pos car. Is this the belt? No idea please help.
Second, when im in the car I noticed the A/C vents near your face are not blowing much at all. COLD AIR is coming out, it's just not blowing hard.
If anyone could explain what I need to do to fix this I'd be very happy.
Thanks
Cheapest and easiest test, buy a new belt. It's what, 20 bucks and you probably need it anyway.
As for the weak air, is the air powerful from ANY vents? Such as the defrost vents? Do you hear any noise when the fan is on? Like a playing card in a bicycle spoke noise? Yes, the fan could be bad and is beyond extremely easy to replace. Remove kick panel above passenger feet, unplug motor, remove 3 or 4 bolts and fan comes right out. Easy way to see if it's bad is to remove the fan, plug it back in and turn the fan on, being careful of course. If the fan spins weakly, it's likely going south.
Check it out a little more before you just go replacing parts. You proabably do need a new belt but it just chaps my *** to buy parts that I dont have to thave and dont actually fix my issue.
As far as the low pressure, start by cleaning out he blower like previously mentioned. It's free. Good luck
