99 Trans am Lights Wink??
Put in a new motor since the old one when out. I did this for the otherside about a yr ago and no problem. The left side on the other hand is a problem i don t think I installed wrong there is only one way it will go in. And the clip only goes on one way as well. so long story short.
Turn on Drivers side comes up. Turn off lights drivers goes down passangers comes up. ECT. Unpluged battery and pluged back in fuses are not popped. I dont know what is going on. Need some help..Any suggestions?
you have the linkage on the wrong side of the headlight stop also you shoukd be able to see th light turn on even with the light down on the affected side this is common take the 10mm off and move the headlight door linkage to the correct side
