Sponsored by: CARiD
crank sensor voltage???
Old Jul 23, 2012 | 06:34 AM
81cuttysupreme's Avatar
Default crank sensor voltage???
I'm having trouble getting a recent engine swap to run. The motor starts and fires up one out of five starts or so, but then dies 5 seconds later. I dont think its the vats btw, but will double check that too.
I was checking the reference voltage at the crank sensor plug b/c i was swapping out the sensor. From pin A to C i got 10.6 volts. From pin A to B i got 11 volts. This doesnt seem right to me but I'm not sure. I pulled the blue plug off of the ecm to try and check the voltage there, but I didnt get anything on the vom. Does the ecm stop working when one of the plug's are removed?
Old Jul 23, 2012 | 01:55 PM
Please help I need to get this beast on the road.
Old Jul 22, 2020 | 06:19 AM
aknovaman's Avatar
Try testing the sensor like I did. I did find that different manufacturers produce a variety of negative going pulse width; not sure if that matters tough. At least you can test the functionality of the sensor.
Old Jul 22, 2020 | 01:57 PM
WhiteBird00's Avatar
Ungrounded Moderator
I would assume after eight years he got it working or got rid of the car.
