Are rear wheel bearings adjustable?
If so where would I (or the garage) adjust/tighten the wheels or are the bearing that are less than a year old be faulty?
Any help would be most appreciated
PS as I always forget: 99 Trans Am Conv.
At the same time as changing the rear wheel bearings I had the seals and fluid changed in the axel as there was a minor leak. I am going to chat again with the inspector then the garage but the way my luck is these days it's going to be a new axel!!
Before I rush out and get one, is there an after market rear axel that is superior to the OEM? once I have dealt with the money draining maintenance of my bird I would like to spend some upgrading it!!
Thanks again.
Ok, been back to the Inspector and garage. I've looked at the wheel bearings myself and they are definately shot, on both sides! There is no doubt that they need replacing. My garage had not looked at the bearings but wondering if the wheels could be adjusted. In this case obviously not.
Thanks again.
