Help Me Track Down This Squeak!***VIDEO***
other than that i'd say grease one thing at a time till the sound goes then you'll know.
Mine was exactly what a couple of others mentioned, the top shock mount. The bushings they use are kinda cruddy. Some have a ridge molded into them that help the bushing pop into the hole and keep the edge of the hole isolated. Ours don't. It must've moved some after relieving the pressure on the shock-to-body after dropping the rear down to replace the springs. Weird because it's been fine after putting another rear under it a couple weeks ago.
Anyways, removed the nut and top bushing, dropped the rear to relieve pressure and straighten the shock up, jacked the rear back up, coated the hole with lithium spray grease, reinstalled the bushing/plate/nut, and it's gone....for now. Getting to it on a convertible sux.
