Sponsored by: CARiD
Check engine !!! Help
Old Aug 25, 2012 | 04:58 PM
bahrain z28's Avatar
Default Check engine !!! Help
Good morning,
i was driving under normal condition. around 40km/h or so
anyway, the Check engine light came up but everything was running perfect
am having a problem with knocking though its not that big.
i tried down shifting, high rpm, flooring it or abnormal but didn't notice a thing
i even check the fuel cap if its tight and it is.
its a 1998 camaro Z28 i have 127000 KM done
LS1
any ideas ??
thnx
Old Aug 25, 2012 | 05:50 PM
DropTopBird's Avatar
Use a code scanner to check it or hit up an autozone etc so they can pull your codes
Old Aug 25, 2012 | 06:49 PM
roninsonic's Avatar
Pulling the codes is your only option. a check engine light without any symptoms is impossible to diagnose.
Old Aug 25, 2012 | 07:00 PM
if i have low oil will it trigger check engine ?
or it is set only to trigger when there is a problem with emission system.
because i removed the catalytic converters before but already took it to a programmer to do his thing with the o2 sensor
garygnu's Avatar
have the car scanned for the ses code, or you can get a ok scanner from harbor freight for $100 on sale.
Old Aug 26, 2012 | 02:55 AM
now that i have let the car rest and cool down over night i checked the engine level and its low, the oil reaches till (ADD)
Old Aug 26, 2012 | 06:43 AM
ok so i went for an oil change ... it wasnt low but it was dirty now the light is off thank god
Old Aug 26, 2012 | 08:49 AM
wssix99's Avatar
Save the manuals!
This will not fix a check engine light. There is an oil change light, which will come on for a needed oil change.
You probably still have the codes stored in the car's computer. You should get that scanned to see what the problem was. (The condition may have temporarily gone away - but the odds are that it will come back.)
You should be able to buy an inexpensive scanner, which will pull the codes for you from the car's PCM. Form there, you can find out where the problem was by looking up the code.
Old Aug 26, 2012 | 08:55 AM
JUSTINSWS6's Avatar
Probably nothing mechanically wrong
Old Aug 26, 2012 | 06:41 PM
@wssix99 i dont have that light in my camaro but i di have low oil pressure light and my camaro dont have the service reminder light and even doesnt have the oil/trip holding method to reset it ... i hope that it doesnt come back and i'll take it to my programmer to see what triggered it
Old Aug 26, 2012 | 09:09 PM
JUSTINSWS6's Avatar
To rest the oil. Turn key to on do not start press the pedal to the ground three times.
What is your oil pressure at
Old Aug 27, 2012 | 04:10 AM
it is low but it is in the operating range.
its been like that since the day i bought it, or even the pre-owner did
when the oil is warmed up it give me 20-25 PSI idling
consider that i live in Bahrain
Weather temperature is around 40-48C
Old Aug 27, 2012 | 11:46 AM
JUSTINSWS6's Avatar
Thats not right. Check the pressure from a external gauge.
Old Aug 27, 2012 | 01:04 PM
how to do that i can get an external pressure gauge but i have no idea how to use it
Old Sep 5, 2012 | 03:25 AM
anyone?
