Sponsored by: CARiD
98 auto ta wont start!
Old Aug 26, 2012 | 09:39 AM
jagscars's Avatar
Default 98 auto ta wont start!
So I got off work and went to start my car and--- NOTHING. All the fuses are good, swapped around the relays, checked what I believe to be the gear indicator (on the right side of the shifter rachet) and it will turn over when I arc from the solenoid to the positive. THIS SUCKS!! HHELP MEEE!
Old Aug 26, 2012 | 11:22 PM
theskitztikwon's Avatar
Vats maybe?
Try it again see what it does
Old Aug 27, 2012 | 04:17 PM
jam01's Avatar
is the security light blinking? if it is, it is most likely your ignition cyl vats wire is broken. not a hard fix, the cylinder itself is about $50. depending where you go. i took pictures of mine while i had it apart if you decide you want to try doing it. are there any codes or check engine?
