can't find torque arm bushing on rockauto
going to be installing an S60 rear in my 2002.
I already purchased an ac delco transmission mount from rockauto.
I also plan on getting new motor mounts and was going to stick with rubber.
I was not aware until now that there is a torque arm bushing, I would like to replace that but don't know where to buy one from. I can't find it on rockauto, can you?
any other bushings i should look at replacing? My goal is a quiet vibration free ride.
Check on Amazon. I just ordered a replacement for mine. It is urethane, however I don't think you'll find a rubber replacement without going to the dealer for a couple hundred $$$.
Get the urethane. it's also impervious to oil, which probably rotted out your old one. No bangs squeaks or harshness. Better than stock.
You'll want the Energy Suspension 3.1111g
