Sponsored by: CARiD
Dexcool
Old Aug 30, 2012 | 05:15 PM
Ozzy16's Avatar
Default Dexcool
Hey guys, Recently I opened up the cap for the engine coolant reservoir tank and there was this orange sludge **** on the dipstick. At first there was slightly more on it but i wiped it off ( should have left it on for the picture ) anyways, theres lots of rad fluid in the rad (dexcool) but I am just concerned and wondering whats going on here.. Car is a 2000 T/A with 30000 Miles.
Old Aug 30, 2012 | 09:18 PM
LS6427's Avatar
That can happen with Dexcool. I personally have never had any of that in 14+ years with my Trans Am. But some people do.
You could always switch to Green stuff. Just flush it real good, then use the Green.
Old Aug 30, 2012 | 09:21 PM
senicalj4579's Avatar
No one knows for sure but it is said that can happen with dexcool from not doing the proper maintenance. I say flush it out a few times.
Im on my 3rd ls1 camaro and have never had any problems with dexcool.
Old Aug 30, 2012 | 09:31 PM
1 FMF's Avatar
the coolant is rated for 5 years, you are on year 12.
Pull the battery out, undo the coolant reservoir and rinse it out with the garden hose and refill with fresh dexcool. Also blow through the rubber hose from the reservoir to the radiator neck. if you haven't done it, open the drain **** on the radiator and drain it and refill with fresh coolant. No matter what antifreeze you are using after 10 years what do you expect? It needs to be serviced.
Old Aug 30, 2012 | 10:59 PM
Ozzy16's Avatar
The previous owner has had it serviced, but I will do a flush just to be on the safe side...God knows how old it is.
