Sponsored by: CARiD
Knock sensor bank 2 problem
Old Aug 31, 2012 | 12:12 PM
pontiacdog's Avatar
Default Knock sensor bank 2 problem
SES light is on and says knock sensor bank 2 has low voltage, probably means it isn't working.
How serious is this and is it easily fixed? The car runs fine and doesn't really knock.
Old Sep 1, 2012 | 07:37 PM
joshp14's Avatar
Most likely needs a knock sensor. It's under the intake manifold so you will just need a set of intake gaskets and a new sensor...or if you have the extra cash just replace them both since you will be right there. Also, the connectors get very brittle with heat and age so I would also get a new wire harness too. WS6store sells both.
http://www.ws6project.com/user_stor/...-knock-sensor/
http://www.ws6project.com/user_stor/...-wire-harness/
Old Sep 2, 2012 | 01:28 AM
LS1121's Avatar
If you going in there do them both with the updated sensors and wire harness. My tuner turned mine off, not really happy about that.
Old Sep 4, 2012 | 06:52 AM
pontiacdog's Avatar
Thanks guys.
Just to make sure, bank 2 is passenger side in an LS1, right?
Old Sep 5, 2012 | 05:15 PM
joshp14's Avatar
That is correct but in this case the knock sensors are oriented front and back. Front being #1 and back being #2.
