Sponsored by: CARiD
power window needs replaced
Old Sep 6, 2012 | 06:31 PM
lsmaxxed's Avatar
Default power window needs replaced
I need to replace my drivers side power window motor i need some tips advice and possibly a writeup and pics any help appreciated
Old Sep 6, 2012 | 06:33 PM
sdimex's Avatar
i got a motor if u need
Old Sep 6, 2012 | 06:38 PM
Ruthless909's Avatar
http://shbox.com/page/windowmotor.html
Old Sep 6, 2012 | 06:49 PM
lsmaxxed's Avatar
The hardest part looks like knowing where to drill the panel to expose the rivets, any advice on drilling the panel?
Old Sep 6, 2012 | 07:29 PM
lsmaxxed's Avatar
Anyone?
Old Sep 6, 2012 | 07:44 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Originally Posted by lsmaxxed
Anyone?
My advice is to follow the link that was provided already:
Originally Posted by Ruthless909
It will come out perfect if you follow those instructions. Once you get the door panel off, and compare what you see in front of you to the pictures in that link, it will be very obvious where to drill the access holes.
Old Sep 6, 2012 | 10:40 PM
02CamZ28's Avatar
I believe I followed that link and everything worked out good
Old Sep 6, 2012 | 10:46 PM
^^^ What he said.
Old Sep 7, 2012 | 08:26 AM
wssix99's Avatar
Save the manuals!
Be sure to purchase a Dorman replacement motor. (A search will tell the story as to why.)
Old Sep 7, 2012 | 12:13 PM
FiredUpZ28's Avatar
I'd get a regulator with the motor on it and four GM rivets. Takes about an hour to do including taking the door panel off.
Dont. Just put the regulator assembly in and be done with it.
Old Sep 7, 2012 | 12:49 PM
RPM WS6's Avatar
I wouldn't bother with regulator replacement unless the window isn't going up straight or sitting correctly in the door.
Old Sep 7, 2012 | 05:52 PM
Why would anyone want to replace the entire regulator assembly and spend more money when only the window motor is bad?
Old Sep 8, 2012 | 01:58 AM
myk's Avatar
myk
Yup, that regulator assembly will probably accompany the car to its final resting place. Don't over-fix the car, just fix it...
Old Sep 8, 2012 | 07:38 AM
wssix99's Avatar
Save the manuals!
I don't think the regulator needs to be replaced, but it does need some love. Using some Sil-Glyde to lube up the tracks and rollers will keep everything working much better. (This is the original lube for these parts and will keep the reg happy.)
Old Sep 9, 2012 | 09:34 AM
lsmaxxed's Avatar
Easiest thing ive done for my car
Old Sep 10, 2012 | 07:57 AM
FiredUpZ28's Avatar
I've heard all this before on here but seriously I've seen TONS of motors fail a year later because the regulator is not straight, worn out, or binding up. I highly recommend replacing it with the motor because its SOOO easy. No drilling into your already-weak fiberglass door needed and your not risking the window slipping and having the regulator spring unwind (talk about fuuuuun sh*t!!) either. Take my advice or leave it but I'm giving it from actual field experience not from bouncing forum to forum.
Old Sep 10, 2012 | 10:58 AM
RPM WS6's Avatar
I replaced the driver's side motor on one of mine about 3 years ago. Original regulator works just fine still. Install was easy, the door has not crumbled from drilling access holes, and no horror stories have unfolded due to this repair.
This is good advice, and something I didn't remember to do last time I had the door apart. I will next time though.
Old Sep 15, 2012 | 01:54 PM
AmDWs6's Avatar
if you are still looking,
i just ordered the XXXX kit didn't receive it yet
there's a whole kit for the price of 325$ two dorman motors with express down kits etc.
i guess you can find a single motor at ws6store too.
Last edited by wssix99; Sep 15, 2012 at 06:31 PM. Reason: non-sponsor link removed
Old Sep 23, 2012 | 10:45 AM
rouseyss's Avatar
This couldnt have come at a better time as my passenger window motor is having those symptoms listed
Old Oct 7, 2012 | 09:38 AM
lsmaxxed's Avatar
Its really easy to swap the motors out no problem with anything else in the door though.
