A/C Clutch Bearing Replacement?
Yes , you remove the belt then the center bolt then using the correct puller ,,,,,probably Autozone free tool rental pull the clutch assembly , then remove the large snap ring and using a large socket or something metal and solid just smaller than the bearing ,,,,,pound out the old 1 ,,,,,,,,reverse to install .
I would go with a rebuilt compressor, assume you are working on this still mounted in the car? You might go ahead and unbolt it and be able to get a different angle on it, but at the point of breaking two pullers I would punt and buy the compressor.
I changed my A/C Clutch plate and found this thread useful. I used the same AZ OE kits shown in the pictures. If you have not seen it, I bet it will help, post #25 is the start of the good info.
https://ls1tech.com/forums/general-m...-clutch-2.html
