Sponsored by: CARiD
re-ring or wait?
Old Oct 1, 2012 | 03:56 PM
treefingers's Avatar
Default re-ring or wait?
I have a built 383 that is consuming an alarmingly larger amount of oil. Probably around 1qt/1k There are no ostensible external leaks, and there is oil stains on the bumper from the exhaust. It doesn't always smoke at idle; although, it does occasionally. It does, however, smoke under WOT.
I plan to do a compression test whenever I have the time, but what else can I do, especially if the compression tests fine?
Old Oct 2, 2012 | 12:54 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Just out of curiosity, what heads are on the car, and have they been ported?
If they HAVE been, were the intake rocker arm bolts sealed?
How old are the valve seals?
How many miles on the short block?
Old Oct 2, 2012 | 09:50 AM
They are stock 243s, and I am not certain how old they are. They are much older than the shortblock, which has less than 10k.
Old Oct 2, 2012 | 10:23 AM
1 FMF's Avatar
check your crankcase pressure and your pcv setup.
Old Oct 3, 2012 | 11:35 PM
I've pulled some of my plugs, and none of them were oil stained. I emptied the catch can, and there was a tiny amount. My PCV setup is routed fine, as far as I know. This may be a stupid question, but how do I check crankcase pressure?
Old Oct 10, 2012 | 12:30 AM
So, I have good compression in all eight cylinders. Two adjacent plugs had a significant amount of oil residue. Now, I'm assuming that the valve seals are above those two cylinders, or my PCV system is inadequate.
