Sponsored by: CARiD
pulley replacement video
Old Oct 9, 2012 | 01:26 AM
98FoRmULa_BiRd's Avatar
Default pulley replacement video
I need to replace my idler pulley and my ac tensioner pulley. I found this video which I found to be very helpful.
My question is that the video says I can use a tensioner pulley as an idler pulley and vise versa. The tensioner pulley's are only $10 bucks and the idler pulleys are around $30. Is there a better brand that you guys would go with? Trying to fix my squeek for cheap and wd40 just isn't cutting it anymore. What do you guys reccomend as far as a good pulley for a good price?
Old Oct 9, 2012 | 01:31 AM
usnfenix's Avatar
im not too sure about your question, but when i went to replace mine i just got the oem part that belonged there. its only a few bucks more why not lol. the install is easy as hell you wont need a video.
Old Oct 9, 2012 | 09:04 AM
beyonddisturbed's Avatar
the tensioner pulley and idler are the same size pulley but the tensioner pulley will come with a new tensioner assembly not just the pulley. I got mine at advance they are billet instead of OEM plastic.
Old Oct 9, 2012 | 07:30 PM
sjsingle1's Avatar
dayco makes a metal pulley for the a/c.......i have 2 of em
Old Oct 10, 2012 | 12:49 PM
Element's Avatar
You might pull the original pulleys off, pop the grease seal off, and re-grease them. As long as the bearings haven't burned up, a good high-temp marine grease should take care of the issue.
Old Oct 10, 2012 | 01:14 PM
94'BLKBRD's Avatar
This
Re-grease the pulleys before you buy new ones.
