Why is my car running hot?
I got a 98 camaro with 02 ls1 motor somehow i cracked a radiator so i replaced it. It ran fine for two weeks and it started running hot again so i replace the thermostat and it still gets to the 210 range it has never been that hot. Its always been right at the second line between 160 and 210. I dont think the heads r warped cuz it would get over 210 but it never gets over 210. Can anybody tell me what's up?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
if your coolant is boiling out, and all you did was replace the radiator and you know your thermostat is good, i bet air pocket. check your coolant cross over lines first and make sure they are going to the right port on top of radiator. if that is good pull the top hose off that goes to the water pump and fill it with coolant till it starts coming out and re-attach to the top of the radiator. then check the levels in the overflow and the radiator and start it up and run it.
