Sponsored by: CARiD
console interior light problems
Old Oct 24, 2012 | 07:48 AM
ryany's Avatar
Default console interior light problems
Are they a trick to getting the little light bulb out where the shifter is in automatic Camaro. I have tried everything it still wont come out. Any help
Old Oct 26, 2012 | 01:21 PM
Atrus's Avatar
If you are talking about the light for the shifter plate, you just remove the plate itself from the two bolts under the center console lid, then slide it out, and the bulb socket is locked in place by turning it, so you just turn it and it would come out. If the bulb is stuck in the actual socket you might need to very delicately use pliers to pull it out or you'll break the bulb.
