Sponsored by: CARiD
wierd light/electrical problem help!!!!!
Old Nov 24, 2012 | 07:56 PM
shaun's Avatar
Question wierd light/electrical problem help!!!!!
hey guys got a problem my lights are flikering a little at a fast pace i notice it even doing hwy speed its barely noticable but i can see the gauge flicker.
the battery and alt tested fine it gets worst when i turn up my system but it still does it when its not on.
what can this be?
Old Nov 24, 2012 | 11:30 PM
shaun's Avatar
oh and when this started the voltage on the gauge is higher than it normally was befor
it started it guess the right word for whats happening is its surging.
Old Nov 25, 2012 | 12:12 AM
sixvi6-camaro's Avatar
Probably the Voltage Regulator which is inside of the alternator. I'd get a new Alternator and be sure the wiring leading from the alternator to the battery is in good shape as well.
Old Nov 25, 2012 | 03:54 PM
Harland's Avatar
Lightbulb check ground wires battery check wires clean.
unbolt wire ground clean and keep maintinance on battery as well.
