Moisture in fuel
The more full you can keep the tank, the better.
The air in a less than full tank contains moisture. For a car that is parked outside in the weather this air in the tank, and the tank itself, will go through many cycles of warming and cooling as the temperature outside changes.
This warming and cooling will condense water out of the air and deposit it in the bottom of the gas tank.
Each time the air warms up it will expand, driving some of the air out of the tank, and when it cools again the air contracts and draws in new air with new moisture.
Keeping the tank full of fuel eliminates the air space and the problem.
You are misunderstanding how the EVAP system works. The tank can never be 100% sealed at all times, because air must somehow be allowed to replace the fuel that is consumed by the engine, otherwise vacuum would eventually collapse the tank. There is a vent system to allow air to be brought into the tank. This air contains moisture (unless outside humidity is at 0%).
The system is sealed only in the respect that it does not vent fuel vapor to the outside, but it does draw outside air into the tank as needed.
