Sponsored by: CARiD
Bosch Spark Plugs???
Old Dec 19, 2012 | 11:25 PM
Gerardo.'s Avatar
Default Bosch Spark Plugs???
So ive read that ppl dont recommend Bosch spark plugs. A buddy of mine gave me me some Bosch Superplus spark plugs for free would u guys recommend i use them or just save up for something else???? Has any one had bad experience with them???
Old Dec 20, 2012 | 10:55 AM
Blackpanther99's Avatar
Ive used those on my bone stock Trans Am I had no issues what so ever. But I would investigate more before using them. They worked for me.
Old Dec 20, 2012 | 04:18 PM
Gerardo.'s Avatar
Ive read on here that they arent really good but havent really herd of ppl have bad experience with them...ima try looking more into it....
Old Dec 20, 2012 | 07:30 PM
poltergeist 02's Avatar
I use NGK tr55's
Old Dec 20, 2012 | 07:35 PM
lsmaxxed's Avatar
Ngk plugs and msd wires for 80 bux ws6store.com
Old Dec 22, 2012 | 02:43 PM
angel71rs's Avatar
I've used Bosch platinums on all 3 LS1s Ive owned, no problems to report.
Old Dec 22, 2012 | 08:34 PM
I wouldnt risk it, just go with NGKs they work great also
Old Dec 22, 2012 | 08:49 PM
bayer-z28's Avatar
NGK's... I've had nothing but bad luck with Bosch plugs. Just stick with a Simple NGK Tr55..
Old Dec 22, 2012 | 08:56 PM
Greed4Speed's Avatar
I've used Bosch, Denso (stock from GM), NGK, and Autolite. They all worked.
Just so they're the right heat range you have them and they were free. Throw them in and see how they run. If they run rough, pull and replace with another
Old Dec 22, 2012 | 09:41 PM
bwkmaro's Avatar
Im not a fan of them people have preferences but if you have a performance motor pretty everyone can agree on ngk's being top notch no matter what the build or application
Old Dec 22, 2012 | 11:02 PM
1ta ls1's Avatar
Just installed the Bosch Ir's last week, replacing the stock AC Delco. Had the Bosch plugs and wires laying around, so I thru them in. Not bad. But I am switching to NGK TRT55s once I get my headers. The Bosch are comparable to AC Delco. But I still prefer NGK TR55s and MSD wires.
Old Dec 24, 2012 | 07:23 AM
Marc 85Z28's Avatar
LS1s don't use a waste spark ignition, which is where the shitty Bosch reputation comes from. They DO NOT work in waste spark systems. However, this does not mean it's OK to run them in other applications. They're overpriced and poorly designed. You can find better for cheaper.
