Rear vibration after engine/trans install
Pulled engine and trans and replaced rear main and oil pan seals in 02 z28 6 speed. Put everything back together and went rather smoothe. The torque arm bracket was only taken out of mount at trans and swung up out of way and reinstalled into mount. No more engine leak but I have a vibration coming from rear of car that I did not have before. It gets louder the faster you go and changes with speed no matter what gear is in...even coasting in neutral. Any idea what this could be? Thanks! By the way flywheel and clutch were in good shape so I did not replace.
Id check alignment of the driveshaft first, make sure everything is in there right, then take a look at the u joints. they will cause vibration if there going bad, how many miles on em?
