Umi torque arm and driveshaft issue or.. pics
So my car shakes. has been for a while ran through everything I could, shaking was coming from the front. tie-rods were bad, replaced and replaced the rotors too, then aligned. then it got better after each installl until it started slowly getting worst. wheel hub assembly was replaced today. doesn't shake as bad. eased it up majorly but it feels like a drive shaft now. coming from the bottom.
nowstock driveshaft back in the car, car has shattered a tail shaft housing prompting me to go ahead and swap the pan hard bar, LCA's and an adjustable torque arm relocation kit all from UMI. the TA bracket was too low, got the one it said to get for LT's btu it hit everything on the road bent the mounting brackets a bit which will be one of the pics. I got a new bracket and custom exhaust to fit. car makes a thud sound shifting from Park to drive to reverse also.
aside from that the driveshaft is sticking out way too far in my opinion. but everyone says it's fine, pic of that also.
also, crush sleeve, what would you expect if your crush sleeve isn't right? i had everything marked and thought it was good. feels like it is. After we installed the pinion yoke it was fine. nothing it didn't do before.
any help is appreciated. car shake worst in higher speed and when I try to get on it, it shakes more and feels like something wants to give. I know the transmission is also over flowed a lil bit
I chased my *** on my car after installing adj tq arm and relocation bracket....turned out my back wheels were bent and the vibration was transferring more into the body since I stiffened everything up. Could b as simple as needing a balance
