MAF question?????????????
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0507 Idle Control System RPM Higher Than Expected
P0480 Cooling Fan 1 Control Circuit Malfunction
P1635
Description
5 VOLT-REFERENCE "A" CIRCUIT
PCM uses 5-volt reference "A" circuit as a sensor feed for
EGR valve pintle position, fuel tank pressure (VIN K), MAP, and TP
sensors. PCM monitors voltage on this circuit. If PCM senses voltage
out of tolerance, DTC P1635 sets.
Symptoms (P1635)
You likely won't notice any drivability problems.
Causes (P1635)
PCM detects an out of tolerance condition on the 5-volt
reference "A".
Solutions (P1635)
Check for faulty connections or damaged harness, MAP, MAF, TPS, etc
i hope this helps
P0481 Cooling Fan 2 Control Circuit Malfunction
doesn't always mean a fuse is your problem, try to directly make the fans work see what happens.
for P0507 the only solution is with the tune as the tuner will lower down the idle rpm.
it should be around 850rpm at idle. or a friend or you could do it if you/he/she have HPTuners.
swapping out your O2's is really going to help with p135 & p154 but keep in mind it might not disappear right away. since you mentioned that the passenger's side O2 wire is cut well that's your problem for P154.
now that you removed your air pump more codes will show just ignore them.. most of those codes will be gone once the tuner see's them(Air pump must be disabled from the computer itself).
check the sensor for water level might need replacing.
if you mean get that fixed well, i suggest you start from what i said, try to directly make the fans work see what happens, just take 1 wire from the battery (+ terminal) and touch it with the voltage feeding wire.. to find out which wire that is, use a tester.
if they don't well then guess what needs to be changed
here's a wiring diagram, from that i would want to check the controllers, you said you've changed the relays, do you mean the relays or their fuses? If you mean the relays then check their fuses if you mean the fuses well test your relays if they actually get any voltage.
http://img.photobucket.com/albums/v3...995_BOTTOM.jpg
There is a cool fan fuse 40A AND 10A check them, although i'm not sure if it would help tbh.
here's a pic of that too ( 3 relays 3 fuses are in the same box)
http://i207.photobucket.com/albums/b...tionblock1.gif
