Cooling fan comes on for no reason
When the fan runs like you say it does.....is it one fan or BOTH fans?
Because with a properly running fan system.......BOTH fans always go "on" and "off" together as well as operate in both high/low settings together. So if you have just one fan coming on and not both when temps are definitely cold.....there's something else going on.....
You could pop the two pin row covers off the top of the PCM.....just loosen one bolt per cover and then wiggle the tops off till they pop off......check the pin rows in the covers to see if any of them are burnt or discolored. Then take a look at all the pin rows themselves on the PCM for burnt pins or discoloration.
You could try swapping with A/C or something to test.
Next time the fans come on when its cold....grab the bundle of wires coming right out of the PCM ( wiring harness) and move it back and forth and side to side.....see if the fans go off and on.
