Sponsored by: CARiD
preventive maintenance?
Old Feb 21, 2013 | 08:39 PM
demonspeed's Avatar
It's not mine! woo hoo!
That Thunder Racing LS6 PCV kit is $70 overpriced. I got mine shipped for $100 (pm me if you'd like to know where as they're not a sponsor). You'll also want to pick up new intake manifold gaskets; you can get Felpro from any parts store or go with the GM/ACDelco.
It seems you've got a good start for the maintenance. I'd also suggest a fuel filter (as has been mentioned) and at the very least a new PCV valve if you're not going to change to a LS6 PCV setup.
You may also want to get a new A/C and serpentine belt. If you plan on putting an underdrive pulley on, that'd be a good time to do the belts (especially since you need to buy shorter belts).
Old Feb 22, 2013 | 03:26 AM
xenergyx's Avatar
I got valve and air gaskets all fel pro I need to replace knock sensor I have a code for that.... so those sensors will get replaced too
And I replaced the fuel filter already
Old Feb 22, 2013 | 09:01 AM
demonspeed's Avatar
I suggest sticking with the ACDelco sensors. I've found the best price on AC stuff is Amazon...
