Replacement ac compressor?
Be sure to replace the accumulator and orifice tube and it's highly recommended to replace the condenser especially if the compressor blew up. They are almost impossible to flush completely and guarantee a job to stay together correctly. Best bet is OE gm.
1st: 12mos/12k mi
2nd: Lifetime compressor, labor not included.
3rd: Lifetime compressor and labor.
The GM Service Policies and Procedures Manual Section 1.1.4 (June 3, 2013) defines what's now called the "GM Certified Service New Limited Lifetime Parts Warranty (LLPW)". A handful of parts are included for this great OE coverage including compressors, coils, fuel pumps, starters, alternators, shocks, bearings, water pumps.
Be careful though, as the coverage of labor is at the dealer's discretion. Be sure to have the SA add "Lifetime parts and labor" in the notes of the receipt.
1st: 12mos/12k mi
Yup. Two weeks ago I went back to my dealership (Sheehan Pontiac) and got a brand new compressor and they also installed a new A/C line that goes from the back of the compressor to the bottom of the condenser ($120.00 line)........all for FREE under my lifetime parts and labor warranty. And of course they recharged it. I got that warranty at NO EXTRA CHARGE about 7 years ago when I got my new compressor installed at that dealership.
Also, why it was in the air we noticed that one of my end links was missing a bushing. So while they were swapping the A/C stuff I called Advance and had some new front end links sent over. The mechanic put them on for me in like 5 minutes. NO CHARGE. I gave him a $20.00.
My Lifetime warranty just paid for itself and then some..........it's nice to have the dealership bent over the barrel for once.....lol
I wish I had known about these programs before. Thanks to LS6427 for posting about this!
My dealership is really a pretty awesome place, not at all like most dealerships.
When I still had my aluminum 427ci in the car like 10 years ago:
I stripped the bolt that held my A/C tensioner pulley on. So it would get loose and throw the belt off in just a few miles of driving each time I tightened it. I drove over to my dealership and told them about it. The service writer called the A/C guy over and the technician said that to fix it you have to use a sleeve kit because the aluminum is stripped out. The service writer said I'm heading to lunch if you want to deal with it while I'm gone, go for it. The technician told me which bay to drive my car around to and he put it right up in the air. Took the stripped bolt out, drilled the new hole, tapped the new threaded sleeve in and put the tensioner back on. He was done in like 15 min. I was like, OK, so how do I pay for it. The technician was like, see you later man, have a good day, don't worry about it. So of course I tossed him a tip of like $20.00 and I left.
Cool place. I also buy everything in the parts department for WAY less than retail.
The moniker "stealership" would not exist IF even half of them were HALF as GREAT as that one sounds.
My compressor hasn't "blown" so the dealer says no accumulator replacement (i.e. not metal shavings).
I hope they don't look at my receipt in 7 years and tell me no accumulator = no lifetime warranty.....
I drove to my dealership, the service writer asked me to pop the hood right there in the service drive.....he looked down with a flashlight and saw the die. He said I'll have a compressor here tomorrow, come by and we'll put it on.
That was it.......
But there is a problem: vent air clearly not as cold as it was before the work was done.
1. Old vent temp 40 deg (prior to new compressor which hadn't failed but was leaking PAG).
2. New vent temp 45-47deg (set to fresh air, fan at "2", car in motion).
3. Vent temps do not change with ambient temp (between 60 & 80deg, low humidity).
4. Under the same test conditions, my other cars are blowing 38-40deg right now.
Dealer re-checked the charge and it looks good:
Ambient: 59deg (FSM chart only goes down to 70-80deg)
Low Gauge: 30psi (Range 24-34 for 70-80deg)
High Gauge: 125psi (Range 115-190 for 70-80deg)
Vent: 45deg (Range 34-38 for 70-80deg)
Measured refrigerant weight within 0.2 (oz. I think) of spec.
So according to the chart and my original measurement, it's about 5-7 degrees warmer vent air. This doesn't sound like much, but it makes a huge difference in the summer.
The SA is providing excellent service and wants to get this fixed, ideas?
