Norris catch can installed with pics...
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Got it today and voted for the silver. Blends in and looks pretty damn good.
![](http://i489.photobucket.com/albums/rr253/senicalj/IMG02152-20130312-1023.jpg)
I had to cut some of my hard line (plastic) pcv pipe back. Fit together nice with a 90 bend on top.
![](http://i489.photobucket.com/albums/rr253/senicalj/IMG02153-20130312-1319.jpg)
I used teflon tape to seal all the threads.
Used an old torque converter bolt and 2 washers (so bolt would not bottom out)for the bracket.
I chose to install the pcv valve after the can. I figure it will keep the valve clean and let the can do most of the job. After all, thats what the can is for.
I also installed the can lower than the pcv valve. It makes just a little pitch that may help keeping oil in the can.
It fit great and I like it![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
![](http://i489.photobucket.com/albums/rr253/senicalj/IMG02154-20130312-1319.jpg)
Your car ever have the famous pinging? My new motor started pinging around 1200 miles, found gobs of oil in the intake. Sea foam cleaned it up at wot, but I still get a little when cruising at low rpms and heavy throttle.
Looks good. I ended up doing the compressor filter inline with the pcv. Working good so far, but doesn't look this nice lol.
I was thinking on doing that too but I liked how the bracket and everything came as one package. Thanks.
Thanks. Well, it took me this long to do one so its never too late lol.
