Horn doesn't work, but I can hear the relay clicking
Hi all,
Ok so my horn is not sounding. Trying to figure out why.
1. Press the horn buttons, both of them. No horn
2. Press the horn button and with hood open and fuse box open listen, hear a click from the fuse/relay when I press the horn.
3. Swapped the relay out for the next one and same result, clicking noise but no sound from the horn.
What does this mean guys?
What should my next step be?
Thanks
Alex
Thanks
Alex
The following users liked this post:
jfxiao (05-04-2024)
People always forget about the grounds lol...
Do yourself a favor and go buy a $20 DMM (digital multimeter), and go find your horn. There are generally two wires attached. One is a power wire, one is a ground.
The power wire (one of the two) should have 12volts DC or more if the car is running. To do so, put the meter in DC Volts mode, put one lead on the negative of the battery, while someone is holding the horn down, put the other lead on one of two of the terminals. At least one of them should read 12volts or higher. If it's lower than 11v you have a bad power wire somewhere. If BOTH of the wires read 12v, well you definitely have a bad ground.
If you read 12v on one of the two wires....time to check the ground wire.
The ground wire, you need to check for continuity. Put the DMM in "Ohms" mode or the horseshoe sign. Put one end on your - on your battery, put the other end of the DMM on one of the wires coming off the horn. If you read anything over 0.3ohms (OL, or no reading) you have a bad ground. 0.0 - 0.2ohms is acceptable. The lower the Ohms, the better. 0.0 is perfect.
If both of the tests conclude you have a good power, ground, then you have a bad horn unit.
I know this is a really old thread. But I really want to thank you guys. I never tried to fix any issue with my cars before. But my horn did not work all of a sudden and my favorite garage is busy and I would often need to make a reservation 2 weeks in advance. Following the discussion, I found it is grounding issue. I simply loosened the screw of the horn (and did not even take if off) and shake off the dust and tightened it again, then the horn worked like a charm.
Thanks.
Thanks.
wssix99 (05-06-2024)
