Flooded ls1. Need help diagnosing what happened
Flooded my engine. I tried turning it back on a couple times but it was dead. Had to push it out onto dry area. Tried tuning it on & hours later and it sounded like I blew a gasket or pistons I'm not sure what exactly. All I know is that bolts And pieces of metal came out from under the car. I need to know exactly what's wrong and what I need to get fixed. This happened earlier today on my way to work. It's a 2001 camaro ss
Well what are the signs? Do I look for pistons or blown gaskets. My motor looks intact. I checked and all I see are pieces of my oil pan. Just the bolt and little fragments. Not sure what happend?
Yes. My car turned off and would struggle turning on so I guess it flooded and wouldn't turn back on. So I pushed for a bit and I tried it again. It turned on but sounded nasty and I tried reverse and I hear metal scratching and it turned off again. Then 8 hours later I turned it on again and it spilled mi oil and broke my oil pan?
The water was not that deep. Not deep enough to get inside the car or in through the exhaust. The only thing is that the car is a bit lowered from the front. Still not so low that it would go inside
