Sponsored by: CARiD
Burning oil
Old May 25, 2013 | 12:15 PM
thecabani30's Avatar
Default Burning oil
Hey guys , recently bought a 2000 ss . Noticed I was burning oil and found the oil pan was seeping. So I replaced at Chevy dealer. One week later i check the oil and I've used half a quart with no leaks under car. Are these cars bad about burning oil? What do I try next
Old May 26, 2013 | 10:23 PM
1_MEANZ28's Avatar
does the car puff smoke when turing on or if u give it a little rev ? if so probly your valve seals are out..
or
try this..turn on car have a friend rev the car to 3k and keep it there. you check if its smoking lightly or alot..if so your rings are going out ..
best of luck
Old May 27, 2013 | 07:36 AM
flattusmaximus78's Avatar
It's probably being sucked up through the pcv into the intake manifold and sitting in there.
Old May 27, 2013 | 08:05 AM
Forcepower's Avatar
+1 on pvc sucking oil, if you drive it hard. if there is oil in the manifold do the ls6 valley cover upgrade.
Old Jun 11, 2013 | 07:01 AM
the issue was the pcv taking in oil. thank you all
