window track grease?
my passenger side window is working but it slow would greasing the track help?
its not over heating or any thing its constant up/down just at about 70% up it gets really slow
how do they get adjusted? its not tilting or ant thing going up or down?
LS1Tech Administrator
Received 1,712 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
It probably just needs a new window motor. They get slow, then slower towards the end, then they sometimes won't go up all the way without a cool down period, and then eventually they just stop working.
wssix99 reminded me a while back about a great product called Sil-Glyde. Good lubricant for the purpose of the regulator (wish I had remembered when I had mine apart), but at this point I think you'll need a new motor to go with it.
Save the manuals!
^^^ I always lube up with the Syl-Glyde when I have the doors open.
It's a good practice to keep the regulators happy, but probably not the issue here.
As RPM WS6 pointed out, it could be just a weak motor. The motor works a little harder at the top, so this may be why its changing. Part of the reason it works harder is because of the glass contacting the window stabilizers.
Before changing the motor, I'd check the stabilizers for proper adjustment. If they are pressing too hard on the glass, they could be putting too much stress on a good motor. (This happened to me before I knew what I was doing re: the door adjustment and I messed with the stabilizers when I shouldn't have. Your previous owner may have done the same.)
This site gives a good procedure on how to make sure the door is properly adjusted: http://shbox.com/1/adj_window.html
As you operate the glass, you may also look to see if the window is slowing at the point where the stabilizers are making glass contact.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Swapped out my R\S motor last weekend $50 AC Delco
It's pretty easy takes about the same time to R&R the door panel
as it does to swap the motor. Damn shame though that AC Delco
parts made in China.
The old GM window motors used to be made in mexico, not china. So I wonder if GM is just reboxing Dormans and selling them as their own at this point?
GM has been doing this with other things recently as well. For example, if you buy new headlight modules for a '98-'02 Camaro from GM, you will get a unit that is manufactured by Depo in taiwan - the same company that sells replacement headlights via several online retailers. Several years ago, when you ordered them from GM you got a made in USA piece that was identicle to the assembly line originals, and slightly different than the aftermarket Depo versions.
Save the manuals!
My unscientific belief is that all of the GM motors are reman of some sort. Before I switched, all of the "new" ones I had were stuffed in t cases.
There is no way GM is still making a truely new part first installed in a 1960's model. If a supplier was still making them new (like Dorman) then we'd see them also listed under that other brand. (like when Siemens was making them)
I'll bet the reman company for these just moved from Mexico to China.
For the guys that said the stabilizers needed to be adjusted you was 100% correct in this case I moved them out a touch and the window is now going up correctly
Thanks for he help!
Thanks for he help!
I remember reading on this site before that the real issue with F-body window motors is the wiring harness. The wires are too thin of a gauge and it causes the motors to wear out prematurely. Not sure if anyone has had success with beefing up the wiring. I just replace my motors every few years.
Save the manuals!
Keep in mind that this motor was first installed on cars in the 1960's and it came out of the parts bin for these cars.
Lots of people have had success doing this and by bypassing the harness with a relay and direct battery connection. It makes a bad motor look better. The catch is that its less expensive to purchase a lifetime warranty motor.
