Sponsored by: CARiD
Old Apr 29, 2016, 04:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
Print Wikipost
Strange Air Conditioning Problem
Old Jun 26, 2013 | 01:18 PM
1 FMF's Avatar
Originally Posted by Marc 85Z28
I PREFER that my vehicles run on the edge of freezing the evaporator which is why I run everything I own slightly undercharged with an orifice of my spec (when possible). I like a 34F vent temp on a humid 90F day!
it does not work strictly on pressure = vent temperature.
while lower pressure of r134a boils at a lower temperature, you lose cooling capacity because your evaporator coil which the hot air passes over and where the heat transfer happens is not completely full of boiling r134a to absorb the heat. because of being undercharged, on hotter days the evaporator is less than full of boiling refrigerant and its the boiling of refrigerant when it changes from a liquid to a gas that absorbs the heat. when it's already a gas or vapor in the evaporator it's not taking the heat from the hot air passing over it.
in the orifice tube system on our cars you want the system fully charged and that allows the evaporator to be full of boiling liquid refrigerant and is why there is an accumulator canister prior to the compressor to ensure any and all liquid refrigerant after the evaporator turns to a vapor before reaching the compressor.
in the pic when you are undercharged, there is less blue (liquid) and more white (vapor) in the coils and when that happens you have less than optimum cooling performance. the low side system pressure is really not that important, you cannot go solely by the r134a temperature-pressure chart where r134a at 30 psi boils at 35°F and think that's what your air temp will be out the vents. your low side pressure may be 30 psi but if the evap coil is only 20% full of boiling refrigerant you will have not air out your vents.
Old Jun 29, 2013 | 03:31 PM
Marc 85Z28's Avatar
I have 5 cars of my own and hundreds of happy customers with 15 years experience to back my statements up. Try it in your own car!!! Theory and operation does not always reflect the real world.
Old Jun 30, 2013 | 08:32 AM
wssix99's Avatar
Save the manuals!
If theory and real world don't match, then one just has the wrong theory or a missing variable.
Another thing to take in to account is that the air conditioner doesn't just run in the summer. Its a part of the defogger and may be called for in the winter. With lower ambient temperatures, I'd think that a system on the edge would be much more likely to freeze up in those conditions.
Old Jul 16, 2013 | 01:39 AM
01WS6/tamu's Avatar
OEMS spend hundreds of hours doing critical testing to determine the correct factory refrigerant charge specifications and it is critical. Weigh it in to the OE required charge amount exactly to factory specs and it will be guaranteed to work correctly. If it doesn't at that point then you have a accurate baseline to then begin doing proper diagnostics to figure where the problem lies.
A few ounces one way or the other can make huuuuge difference in cooling performance especially in high ambient temperature conditions.
