Brake bleed and flush
Im putting new brake rotors and pads on my 2000 SS,
I have always started the bleed process pass rear, drive rear, pass front, drive front
I have however never owned such a new car(old daily was a 78t/a)
I have read all sorts of weird stuff about dealing with the abs unit. I hope to flush the whole system of fluid as I have no idea when it was done last.
But first and foremost ill be bleeding it ***potentially*** when I replace the stuff. I am gonna see if I can just compress the caliper pistons without bleeding the lines, and opening the container lid.
I have read alot of conflicting data all over the internet so anyone know for certain how to achieve my goals?
Brake pedal currently feels great. Only replacing pads and rotor is cause there is alittle vibration when braking and its all OEM stuff.
nothing special needed
crack one caliper at a time and
hook up a clear bottle with a hose
to the bleeder screw.
with the screw open, have someone
pump the brakes until you see clean
fluid.
make sure you keep an eye on master cylinder
not to go dry.
then bleed them out normally and the system
is now flushed completely.
fluid.
not to go dry.
Correct??
http://www.summitracing.com/parts/wmr-w89727
