Sponsored by: CARiD
Problem
Old Jun 7, 2013 | 01:21 PM
Derrick1227's Avatar
Default Problem
So I'm having issues with my 02 Z28 it only has 67,000 miles. Just within the past two weeks I've changed the spark plugs, O2's my pullies and belts as well as a new alternator. Also just switched from Mobile 1 to Royal Purple. My mods are LT headers Volant intake and frost tune. I'm not throwing any codes yet and yet when I'm idling or under slight acceleration it just sputters and acts like its going to die. Under moderate throttle it seems to stop. So any suggestions because I'm completely lost.
Old Jun 7, 2013 | 01:24 PM
1320Chicken's Avatar
Vaccum leak? Loose electrical connection at the coil packs?
Old Jun 7, 2013 | 01:28 PM
The only thing I didn't think about was my AIR hasn't been tuned out and I can hear it running or attempting to run should I pull the fuse to turn it off? I'll check the connections when I get off work.
Old Jun 7, 2013 | 03:52 PM
So here's a little more detailed info. I took the car for a drive after work and the issues while idling had stopped. However when I would be going about 40 and would give it slight gas it would sputter til it got to a lil over 45 then stop. Also WOT there is no sputtering nor when it downshifts for a hill or more speed etc. Only when its slight throttle other than that it is running fine. I'm confused.
Old Jun 7, 2013 | 04:06 PM
Rich-L79's Avatar
Did you replace all those parts to try to cure these problems or did the problems begin occurring when you replaced all these parts?
Old Jun 7, 2013 | 05:02 PM
No I just felt with the car being 11 years old it might be a good time to replace things I had changed the plugs before. But I noticed it after these things were done.
Old Jun 7, 2013 | 05:33 PM
BobDoLe's Avatar
is it a hesitation under load? could be a misfire due to loose plug wire or cracked plug.
maybe the plug wires are too close to the headers.
Old Jun 7, 2013 | 06:07 PM
Rich-L79's Avatar
You should closely examine the spark plugs and plug wire connections to make sure everything is sound. If I had to guess, I'd guess you cracked one of the plugs while you were installing them or damaged a plug wire or didn't get one connected properly.
Old Jun 7, 2013 | 09:57 PM
Okay I appreciate the input I'm going to check the plug wires first and go from there. I'll keep this updated until I get it fixed.
