Rod knock?? vid inside
i noticed a loud tick kind of noise that started happening 3000rpms and up. started doing it 2500rpms and up. now does it at idle.
noise sounds like driver side. i ran the engine with the driver side valvetrain not there and i didnt hear it. put the pushrods in and rockers on and this is how it sounds-
im thinking of swapping the driver side rockers to the passenger side to see if it follows. the lifters are Brian tooley lifters with about 3000 miles on them. Rotella T6 oil used. changed 2000 miles after the new engine went in. 1000 miles on current oil. Comp pushrods checked and ARENT bent. none of my valve springs are broken. Rockers are stock.
im gonna go put the valve cover on and the coil packs so the both sides of the engine is firing and ill get another video.
a couple more tests to perform:
compression check (looking for a bent valve)
switch the rockers from driver side to passenger side (see if the noise follows)
an older tech who used to be a drag racer thinks it doesnt sound like a rod knock. too fast and without those cylinders firing its too loud.
also would it be dangerous to run the engine with the driver side rocker arms off and pusrods out? of course unplug the driver side injectors. this to see if the noise is still there
could it blow the headgasket?
im gonna go lay under the car with a screw driver and put it from my ear to the block (with it running or course)
i just listened to it more,also noticed the ses light is on now. maybe its the knock sensors setting codes. it kinda stumbled to idle after a lite rev. 2 1/2 min vid
in the vid it shows my car warms up halway. my gauge is off so when its halfway its actaully warmed up
