Cant bleed brakes??!!??
Might Vac bad?? Both soft brake lines need replaced?? (closing off when trying to suck fluid out).. I'm lost.. going to try manual bleeding when I get home but now I am worried the brakes were dragging from the soft hoses and not the calipers.. they are the factory lines on a 00 Corvette with 71k miles so they are probably due for replacement.... Ideas?
Obvious thing first, the brake bleeders are facing up right?
Its easy to install the calipers on the opposite side.
This will make it impossible to get the air out.
