Sponsored by: CARiD
elecrical problem i think
Old Jun 25, 2013 | 07:11 PM
ls1praytor's Avatar
Default elecrical problem i think
Hey everyone i have a 1998 camaro ls1 and i have a problem i think its a short in a wire maybe. I had the motor taken out of it and now its back in best and the best way i can describe the problem is that whenever i get on it like in first gear high rpm like around 5000 it acts like its missin real bad and if i get back into it hard it stops i changed plugs and wires and it still does it i hooked a scanner to it and cleared all codes and it ran fine for about 3 weeks then it started again and it completly died and i hooked scanner back up and it said crankshaft position sensor and egr codes and i changed crank sensor and it ran for about a day then i got on to it in first gear and it done it again so idk i think there may be a short somewhere please help
