Sponsored by: CARiD
NO SPARK!! Please help
Old Jul 24, 2013 | 12:34 AM
exodus_gs1's Avatar
Default NO SPARK!! Please help
So I know I could search but I don't know where to begin. I did a 5.3 swap and after little thing and little thing I finally got her all buttoned up. My only thing is she ran fine for about 20 mins drove/hot rodded around then got on the highway and cruise control wouldn't work then I heard like a kinda muffled back fire and rpms where gone and now it won't start. It will turn over but not fire. It's an 02 a4 with a 02 5.3 ls9 cam and ls6 intake. I had my cut out open when it happened so the exhaust was pretty loud and couldn't exactly here where it came from. If anyone could help me with what would cause it to just stop getting spark all together that would be awesome, thanks in advance for any help.
Old Jul 24, 2013 | 03:08 PM
exodus_gs1's Avatar
Ttt needs some help guys. No one knows? Could it be the crank sensor just took a ****?
Old Jul 24, 2013 | 04:02 PM
Homeless2bNY's Avatar
if you can get a scanner on it that has data stream viewing,
watch the RPM while cranking, if it shows 0RPM than
replace the crank sensor and recheck.
there should be a code in history as well.
P0335 is Crank sensor code.
Old Jul 24, 2013 | 06:37 PM
exodus_gs1's Avatar
Cool thanks for the reply
Old Aug 11, 2013 | 09:59 PM
exodus_gs1's Avatar
Ok so the crank sensor wasn't the problem it was some gobblin idk... took it to a shop he said he charged the battery jiggled the wiring harness and checked all the grounds and connecters and it started.
well a few days later it died again. this time it was the crank sensor, replaced it and now I don't have fuel... any ideas?
Old Aug 12, 2013 | 05:57 PM
LS6427's Avatar
The crank sensor was the problem the other day.....they always start to fail over time. By acting up for days and days first.
Fuel would be the cam shaft position sensor if all the injectors are not hitting.
Old Aug 13, 2013 | 11:24 PM
exodus_gs1's Avatar
The cam sensor would cause me not to have fuel in the lines? And the sensor and harness are both brand new
