2001 Camaro SS - window rattles?
Any one have an idea on the best method to fit the power window rattles on a 2001 Camaro SS. I understand that I do have a stiff suspension (SLP diamond subframes, watts link and strano full suspension with Koni's) but every time I go over a pothole or train track intersection, seems the windows are going to rattle themselves apart! ![Guns](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_guns.gif)
I have removed and replaced both window motors and adjusted the window tracks to align properly with no window placement issues whatsoever but the rattles continue!!!
Any assistance is Greatly appreciated = A Million Thanx
[IMG]
Uploaded with ImageShack.us[/IMG]
[IMG]
![](http://imageshack.us/a/img706/5928/wx7v.jpg)
Check for the two felt-lined pieces of metal held on by 10mm bolts on the top of the door when you take the panel off. They like to break off. If you're careful you can pop the door panel off up top and see them. But again, if you're careful.
