Has anyone figured how to change the radiator without disconnecting the condenser?
As the title says. It's time for a radiator on my 99 TA and everything I read says I have to change the radiator by disconnecting the condenser first and pulling it out the bottom. At first it looked like an easy pull but then I looked it up.
Anyway, I don't have the equipment to recover the refrigerant and I have limited time with any space to start pulling apart the radiator without finishing the job.
Any suggestions would be great. I was even considering clipping the plastic radiator tabs, to pull it out through the top, and fashioning something to support the new radiator after it's in place.
You don't need to disconnect the condenser.
Remove radiator shroud.
Disconnect the radiator hoses.
Disconnect the fan connectors.
I believe the fans are slid into place, so you can just pull them out.
The radiator is connected to the condenser with the same kind of tabs that hold the fans in so it should just slide out from there.
When I replaced mine, I used an LT1 radiator from the parts store so there was an extra plastic holder for an A/C line on the passenger side. I had to cut that off because the A/C lines are different for LT1 cars.
New radiator should just drop in and install is reverse of removal.
That's awesome reinforcement. I started panicking because I looked in the Haynes book and they say to disconnect the condenser and pull the radiator out through the bottom. I didn't think that was necessary but I didn't want to get caught with my pants down.
Thanks again, I really appreciate it.
