Sponsored by: CARiD
Strange Headlight Issue
Old Aug 27, 2013 | 02:03 PM
ripgtp97's Avatar
Default Strange Headlight Issue
My passenger side low beam went out again. After I installed the new housing, it came on but only maybe 25% of brightness. At the same time I plug it in, my high beams automatically come on very dim, maybe like 10% brightness. I didn't move any wiring or swap anything so I"m very confused what's happening. It should be plug-and-go, i've done this before. Anyone have insight?
Also, my running light/blinker light int he front works, but doesn't really blink, therefor my right turn signal doesn't work. I don't think its the bulb, could it be the socket itself too corroded?
Help would be good, since I'm in another state and don't want to get pulled over and have to get a new license yet!!
Old Aug 28, 2013 | 06:07 AM
wssix99's Avatar
Save the manuals!
Corrosion in the headlight motor connector can cause this. (The wires for the lights go through the same connector.)
Old Aug 28, 2013 | 07:39 AM
Homeless2bNY's Avatar
You have a short in the wiring that is back feeding power into the other lights and taking away from low beams.
Replace all the bulb sockets and take apart the wiring to see if anything is shorted.
then recheck
Old Aug 29, 2013 | 05:15 AM
wssix99's Avatar
Save the manuals!
Yep. In a Firebird, this happens in the headlight door motor connector 99% of the time. That's the first place to look before tracing wires and ripping out sockets.
