98 Camaro Idle High low (Unstable)
Hi there..
I thought I shud ask the experts here about my LS1 98 Camaro (Stock) problems. My car stalled a few weeks back and I thought it could be the fuel pump. I replaced the fuel pump but it still did not start. Later on I discovered there was not enough power for the injectors and the fuel pump to operate. The nightmare became true and it was the ECU. I got it replaced and the car finally started.
But the issue right now is I don't have a stable Idle. The car idle goes high and low continuously. (High 1200 pm and low 1000 rpm). I tried fixing it by changing the IAC sensor and TPS sensor but still dint work. I looked for air leaks but there are not any.
Can any1 please advise me as to what the problem could be? Or if I have missed out anything to check? Please advise..
